не работет радио оно же монитор для климата.
и свет в дверях потух.
по сканеру вот.
Friday,14,January,2011,12:26:11:30635
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 1K0
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: XW8BA21Z59K153459
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No: 06A 906 033 KD
Component: BSE S71 1.6 2VG 2230
Revision: --H04--- Serial number:
Coding: 0004075
Shop #: WSC 73430 790 00999
1 Fault Found:
16864 - Coolant Fan Control Circuit 1: Electrical Malfunction
P0480 - 009 - Open or Short to Ground
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 15.0°C
Voltage: 12.75 V
RPM: 0 /min
Temperature: 15.0°C
Voltage: 12.65 V
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 JA HW: 09G 927 750 JA
Component: AQ 250 6F 1368
Revision: 00H81000 Serial number:
Coding: 0008520
Shop #: WSC 24800 785 00200
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.lbl
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0016641
Address 08: Auto HVAC (J255) Labels: 3T0-907-044.clb
Part No SW: 3T0 907 044 AC HW: 3T0 907 044 AC
Component: Climatronic 122 0203
Revision: 00003001
Coding: 0100000000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_SK35.rod
2 Faults Found:
13701888 - Function Restriction due to Received Malfunction Value
U1113 00 [009] - -
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 17
Reset counter: 0
Mileage: 9539 km
Date: 2011.14.21
Time: 00:21:38
9481200 - Coolant Pressure
B10AB F0 [009] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 9539 km
Date: 2011.14.21
Time: 00:21:38
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0537
Revision: 00103 AB
Coding: 40180AB8F041B1C040080080110001E4037000AE426D8D605C0440000000
Shop #: WSC 00746 935 70112
Part No: 1Z1 955 119 C
Component: Wischer 08050 22 0601
Coding: 00D7B7
Part No: 1K0 955 559 AH
Component: RLS 070509 05 54 0402
Coding: 0730ED
Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 1Z0 919 475 HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0004
Revision: -------- Serial number: 66640912821756
Coding: 000101
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q2 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2DCU5P
Coding: 0020786
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 055 0111
Coding: 0001532
Part No: 3T0 959 537
Component: E221__MFL-URO H07 0011
Coding: 00000128
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 843 B HW: 1Z0 920 843 B
Component: KOMBI H21 0109
Serial number: 00000000000000
Coding: 110B00
Shop #: WSC 73430 031 00999
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K09512056F
Coding: EDA07F06000202001302
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H21 0109
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2107
Coding: 0004342
Shop #: WSC 73430 790 00000
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.068 H08 1901
2 Faults Found:
00778 - Steering Angle Sensor (G85)
000 - -
00573 - Steering Torque Sensor (G269)
008 - Implausible Signal
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0004342
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
Component: BOLERO 008 0053
Revision: 0A001001 Serial number: SKZ1Z3I8158076
Coding: 0D0004000001
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 9539 km
Time Indication: 0
Date: 2011.14.21
Time: 00:28:44
Address 62: Door, Rear Left Labels: None
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012551
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
End ---------------------------------------------------------------------
если со сканера делать тесты то свет в дверях включается и монитор включается.
уже месяц парюсь, подкиньте версию, что сделать.
SCODA OCTAVIA 2009 радио не работает
