Hi, I'm tryng to read a Hyundai MEDG 17.9.8 (tricore, TC1797) I can retrieve the password, the program chiploader gets access to the mcu but retrieves this error and can't read the flash or eeprom section:
Error: Error while working with j2534
Operation: Reading address of 0. Error code:16
I read the flash and eeprom a few times before, but now, with the same connections I can't read anything. If I leave the ECM in "normal mode" I can retrieve the password and read the entire flash, but when I put the ecm in normal mode the program gets access to the mcu but fails to read and retrieves the error. I don't know about "error code:16". Is there a user manual in english? Thanks in advance...
chiploader Tricore boot mode
LUIS ENCINAS
You should read password for Tricore in normal mode (via OBD2). To read-write flash you should switch ECU to boot mode.
You can ask your questions at info@chipsoft.ru
LUIS ENCINAS
Show me error, please. Error may appear if ECU is not in boot mode.LUIS ENCINAS писал(а):Thanks for answer, I already read the password in Normal Mode by OBD, then I put the ECM in boot mode, load the password and the program chiploader get access to the mcu but fails to read.
LUIS ENCINAS
Here is the error message:chipsoft писал(а):Show me error, please. Error may appear if ECU is not in boot mode.LUIS ENCINAS писал(а):Thanks for answer, I already read the password in Normal Mode by OBD, then I put the ECM in boot mode, load the password and the program chiploader get access to the mcu but fails to read.
http://www.mediafire.com/view/n59u6qe59 ... d_fail.jpg
LUIS ENCINAS
Sorry, I found the error: MY MISTAKE, wrongly I selected TC1797 instead of TC1767...
Now all is ok....
Another question: It is possible to edit the VIN number? I can install the computer and program the key but the VIN number is not the correct. I tried to edit but retrieves DTC P0630 - VIN number not programmed or incorrect unit installed. The car starts and works perfect but I can't rewrite the VIN number, tried with Carman, Hyundai GDS, Snapon solus and many more and it's not possible, all of them retrieves: " VIN already writed".
Now all is ok....
